Hi, I keep getting a random message saying that `CPU fan is not working correctly and to shutdown the PC`althought the fan`s spinning and the temps are good. I`m going to replace it, can I use any 120mm fan? the fan has a 4pin connector which plugs into the 4pin cpu fan header on the mobo. Can you recomend which one to get.
Thanks
Kim
Thanks
Kim
