Joe42 said:
Yep just flip em over to reverse the airflow direction.
Get the zalman 80mm ones and use the supplied resistor. They are cheap and almost as quiet as the nexus ones, plus you have the option of putting them on a fan controller and removing the resistors to get more airflow if thats what you want.
Thanks Joe
Someone pointed me towards the "Sharkoon Silent Eagle 2000" fans which have this golf ball type of dimples on the blades that is supposed to reduce the air resistance and turbulence resulting in quiet operation while maximizing the airflow volume; a review on them here:
http://www.mvktech.net/content/view/2314/39/1/2/
After a little more research I have 3 contenders on my list so far:
AcoustiFan DustProof Quiet:
15.6 dB/19.9cfm/1600rpm (very expensive!dust proof jacket protecting the motor, plenty of connection capabilities which includes a 3-Speed Fan Cable, )
Sharkoon 80mm Silent Eagle 2000:
17.8 dB/22.7cfm/2000rpm (good airflow/connectivity and good price)
Nexus 80mm Real Silent case fan:
17.6 dB/20.2cfm/1500rpm
(Good airflowRPM ratio,good connectivity options)
Man, it's quite in-depth choosing a case fan with so many variables to consider (RPMs, dBAs, Cfm, bearings/sleave, connection types, 12/7.5/5Volt possibilities and outputs and fan lifecycles and warranties...not to mention the difference between manufacturers specs and user/ internet testing site ones...
I am starting to acquire a serious twitch but getting there
Thanks again
S!ap *twitch*
