Coolermaster CM Sphere / Eclipse bits - help!
5 Nov 2010
Coolermaster retention bits - help!
So to cut a long story short, i bought a pair of coolers off the bay, supposidly boxed as new, and while they are indeed boxed and unused, they are both missing their retention clips for AMD processors.
Would anyone who has one of these and only used the LGA parts, happen to have the AMD bits knocking about they wouldn't mind getting rid of?
For reference the eclipse part i need is circled in red in this picture :
This part apparently comes with various different coolers, so even if it's not specifically from an Eclipse, it would work and i'd appreciate it!
It's important that the adjustment clip comes seperate from the main arm as this one in the picture does, as it needs to be able to thread through the gap in the cooler (the only way to install it!)
The CM Sphere part i need is the amd mounting bits top left of this pic :
Any help muchly appreciated!
Ouch.
On a brighter note, that is less than what they charged me for delivery for my custom side panel for my ATCS840.
I was just hoping someone would have one spare :(, so i could avoid the rediculously high postage costs - hopefully from someone with the same or similar fan that installed it on an intel system, thus doesn't need the amd bits.
