- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
This SKU is aimed at low to mid range PC builds with a great set of features including a range of safety measurements and a 80 Plus efficiency rating
Cooler Master GX Lite 500W '80 Plus' Power Supply @ £35.99 inc VAT
GX-Lite power supply is the light version from the original GX series, it specifically targeted at systems in the mid to high range, yet reasonably priced, providing users with unsurpassed cost per performance. Features single highly 12 V rail, proficiently delivering power all the way up to 86%, also supports most demanding components including the processor, drives and cooling fans. The GX-Lite Series will keep the power in your hands.
- Type: Intel ATX 12V V2.3
- Input Frequency Range: 47Hz ~ 53Hz
- Power Good Signal: 100 ~ 500ms
- Hold Up Time: >17ms
- Efficiency: 86% Typically
- Protection: OVP / SCP / OPP
- Operation Temperature: 0 ~ 40?(Nominal Input Voltage)
- Dimension (W / H / D): 150 x 140 x 86 mm (5.9 x 5.5 x 3.4 inch)
- Input Voltage: 180-264V (Auto Range)
- Input Current: 5A
- Input Frequency Range: 47Hz-53Hz
- PFC: Active PFC (>0.9)
- Power Good Signal: 100-500ms
- Hold Up Time: 17ms
- MTBF: 100,000 Hours
- Protection: OVP / OPP / SCP
- Output Capacity: 500W
- Operation Temperature: 0-40?(Nominal Input Voltage)
- Regulatory: TUV / GOST / CE / C-Tick / CCC / KC
- Fan: 120mm
- Connectors: M / B 24 pins x 1 / CPU 4 + 4 pins x 1 / PCI-e 6+2 pins x 2 / SATA x 6 / Peripheral 4 pins x 2 / Floppy 4 pins x 1
Only £35.99 inc VAT.
ORDER NOW
- Input Current: 5A
- Fan: 120mm
ORDER NOW
