Coolermaster PWM Fan Hub - Anyone Used it?
26 Aug 2009
Anyone used the CoolerMaster PWM fan hub? I have six PWM fans for my system, and none of them like running off a standard fan controller (stupid amounts of vibrations). I'm hoping that using true PWM and not voltage modification will resolve this.
So, any opinions on this device? Or know of a fan controller that uses PWM?
Hi, i have read in another thread about this issue of vibration with fan controllers, not used the coolmaster but i have this http://www.overclockers.co.uk/showproduct.php?prodid=BB-004-LP&groupid=701&catid=57&subcat=189 Lamptron Touch its 6 channel, 30W per channel, PMW controlled, nice touch interface and easy to setup and use, each channel can be set manualy or set your own auto profile runs smooth no probs,i run 2x 120mm, 2x 140mm vipers and a 200mm corsair on mine, all is good, considered one of the best fan controllers out there. Hope that helps/answers your question.
Edit : it seems to be out of stock at the moment:(
Well I'm to going to experiment with them vertical once I rebuild this rig at the weekend, see how they perform as standard system fans and not on a radiator.
