Coolers without the need for back plates
18 May 2010
Does anyone know of any coolers other than the Arctic Cooling Freezer 7 pro that will fit to an AM3 motherboard without the need to remove the otherboard from the case please?
Thanks
OCZ Vendetta I am pretty sure can fit using the clip thing for AMD boards without taking the mobo out.
Thanks
X look in my sig for my CPU cooler I can OC my CPU to 4ghz with fan on max and hit 55c after 4hrs of prime 95 and with normal day to day gaming with a OC of 3.8ghz it hits 40-42 with fan on med
hope this helps
All coolers need a back plate. Even the ones that aren't supplied with one, should be used with one.
Wrong post is wrong. The standard fittings are perfectly adequate up to a certain weight, that's why not all coolers require an additional backplate.
Can you see any benefit to using a cooler without one, except for the slight reduction in cost for the manufacturer?
The contact resistance decreases linearly with mounting pressure, and a backplate allows considerably more pressure to be used without harming the board. This is a good thing,
I dont have to remove my motherboard on a system I spent hours putting together and use everyday so for me its a good thing. Also this cooler requires a back plate on Intel based motherboards but not AMD
Plus the test results speak for themselves across the various sites, they arent amazing but that wasnt a requirement and not what I expect from a £30 cooler, what I do expect is it to be easy to install and be quieter than stock, any cooler than stock is a bonus
I'll post back what I think of the Nero S when its installed and I run some basic tests over the weekend
I had this issue, a dremal and some steel wool later and all I had to do was remove my right hand side panel.
Thanks
What motherboard?
My gigabyte GA890 came with a suitable backplate fitted, all I had to do was remove the plastic bracket on the component side and screw the Thermalright bracket through to that.
andy
What motherboard?
andy
Its the 870 version, its all good though i've ordered an Akasa Nero S which uses the standard bracket with a their modded clip
