Coolest running Dual core LGA775 CPU?
Cooled by Passive Thermalright Ultra-120 eXtreme
I asked for LGA 775 not atom, never seem to get any proper answers on here, most people seem technically inept, the Atom consumes Less than 5W, what is withthe 25W?, even a C2D SL9400 runs less than 25W and that is 1.86GHZ 6MB Cache/1066 FSB
WTF..!! Go away and use google or change your attitude. If your not so technically 'inept' then why ask?
Anyhow answer to your question is an E1200, got one in my HTPC idles around 22c under a scythe mini ninja using AS5. Its also under volted by 0.5v and still stable.
What case, and death to google, I use altavista, always have always will, never use lycos, google, jeeves..., how do you know how much to undervolt it by?
The fact that you list Google next to Lycos and Jeeves (it's been called Ask for a long time, by the way) shows that you don't really know what you're talking about with regard to search engines :p
Each chip is different. Fire up Prime95 and gradually lower the volts until it errors. Test it for a day or so when you've found a good setting. This is fairly basic overclocking practice, which you should probably be familiar with before you start criticising other overclockers' technical knowledge.
What are you on about, I don't like google cause I don't like them, not a google follower like most of you, never liked them never will, throwing there money about coupling their shoddy software with everything
hahaha
i think he's funny. in a *facepalm* sort of way
Your vendetta against Google is curious. Lots of their software - Chrome, Earth, Maps, GMail, Reader - is very useful and functional and not at all what I'd call 'shoddy'.
Still, it makes a change from uninformed people criticising Microsoft, I suppose.
Get the highest VID 45nm dual core and undervolt the heck out of it. This may or may not be the answer you are looking for to the question: coolest 775 intel CPU.
Trial and error. Just try an undervolt of 0.25v, boot into windows and prime it for a couple of hours.
Lather, rinse, repeat until prime / orthos fails.
I used the 2 hours based on the average length of a movie being as its in a HTPC, nothing scientific but just pick any length of time you deem suitable.
