- 4 Oct 2019
- Stratford - London
Have you tried enabling LLC with a more aggressive voltage negative offset?I currently have a cryorig A80, and it is just pegged at 90C all the time in games, idles at around 55C, spikes up to 80s just on the desktop for long periods (basically if it isn't completely idle).
So either my A80 has finally kicked the bucket (I do get warm air from the side the hoses enter, but not hot and the far side is usually cool) or it just isn't up to it. Repasting did nothing at all. This is with a mild undervolt btw.
So while I'm not majorly concerned about these temps, the noise is a lot because the fans are just at full tilt all the time and the A80 doesn't seem to allow for separate pump and fan control (there's a harness off the pump that splits to take both fans). Even so, at 100% fans and pump it still can't hack it.
So I'm considering a 360 rad AIO. Am I on the wrong track?
What is your current voltage drop? I applied a negative 0.2 offset and my temps when down quite nicely with my 5700X with LLC mode 3 enabled (mode 1 = quite mild, mode 5 = high, 3 is moderate).
I tried a negative 0.3 offset but the system isn't stable with that.
