Cooling a Hard Drive Advice
26 Jun 2008
Bristol
Hey all.
If a hard drive cant receive cool air across the whole thing and you had to choose a direction for the air to blow, which would be the best orientation?
fan blowing the bottom (underside of the drive) or the top?, or pulling air away from the bottom or top?
does that make sense?>
thinking of installing a hdd in a 5.25 and thinking about just putting a 120cm fan in the bay above or below.
far as im aware the most heat is generated from the underside of the hdd where the circuitry is.... i would say fan underneath blowing onto the underside of the hdd
Think i'm just going to mount another 120mm fan intake where the 5.25" bay is instead. better for cooling better for case air flow.
good point green.
thanks guys.
Whatever you do as well make sure there is good flow through the case. There's no point in having lots of fans blowing air in random directions. :)
Was thinking of doing it in an akasa omega, So a 140mm fan underneith the harddrive blowing towards the top vent with no fan in the vent.
so just blowing out through here
I wouldn't worry about cooling it at all. Recent tests have shown that actually they have a lower failure rate at higher temperatures than anyone previously thought.
Interesting, but that depends on how they measure "excessively cooled".
I think having a dedicated fan per HDD is excessive. I doubt google would have gone to the trouble of liquid cooling hundreds of hdd's just for a study.
