cooling advice please
9 May 2009
I've been recently built the below having used for the last 8 years my trusty a P4 3.4 extreme system cooled by phase change so temps were not a problem.
I need a little advice as you can see the temps on the new system are average any recommendations would be gratefully received.
Anthony.
System
CPU
Intel Core i7 965 Extreme Edition, Socket 1366 (B), Nehalem, 3.2 GHz, Cache 8MB
Cooling Retail cooling
Mainboard
Asus Rampage II Extreme, Intel X58, Sok 1366, PCI-E 2.0, SATA I/II, ATX Rev 2
OverClock None
Memory
TR3X6G1600C8D - 12GB (6x2GB) Corsair Dominator DDR3, PC3- 12800 (1600), 240 Pin, Non-ECC Unbuffered, CAS 8, DHX, EPP
Cooling Corsair Triple-Channel Airflow Fan
Hard Disks
2 X 80GB Intel X25-M, SSDSA2MH080G1, 2.5", SATA 300 MLC
SSD, 250MB/s Read 70MB/s Write speed NCQ (RAID 0)
2 X 1.5TB Seagate ST31500341AS Barracuda 7200.11, SATA 3
Gb/s, 7200 rpm, 32MB Cache, NCQ
GPU
2 X 1792MB EVGA GTX 295, PCI-E 2.0 (x16), 2000MHz GDDR3,
GPU 576MHz, 480 Cores, HDMI/ 2x DL DVI-I, HDCP
Optical Drives
LG GGW-H20L Super Multi Blu-Ray Writer & HD-ROM Reader
LiteOn DVD ROM, Black, 48x CD-ROM 18x DVD-ROM, SATA
Display
24" Dell Ultrasharp 2408WFP Widescreen, LCD1920x1200, 3000:1 , 400cd/m2, 6ms, VESA - REV A01, 1080p
PSU
1000W Corsair HX Series PSU ATX, EPS12V, PS/2, Modular Power Supply, UK Version
Case
Lian-Li PC-P80B Black Super Full Tower Aluminum Case
Keboard Logitech DiNovo Edge
Mouse Logitech MX Revolution
OS Microsoft Windows 7 * 64Bit Buld 7100
GPU Driver Version: 185.85
Release Date: 06.05.2009
Operating System: Windows 7 (64-bit)
Language: English (International)
3DMark Vantage P32208 @ Stock. Not vaild
Temps CPU
Intel Core i7 Extreme 965 hardware monitor
Temperature sensor 0 42°C (107°F) [0x3A] (Core #0)
Temperature sensor 1 38°C (100°F) [0x3E] (Core #1)
Temperature sensor 2 44°C (111°F) [0x38] (Core #2)
Temperature sensor 3 43°C (109°F) [0x39] (Core #3)
GPU
GeForce GTX 295 hardware monitor
Temperature sensor 0 50°C (121°F) [0x32] (GPU Core 1)
Temperature sensor 0 53°C (127°F) [0x35] (GPU Core 2)
Temperature sensor 0 49°C (120°F) [0x31] (GPU Core 3)
Temperature sensor 0 48°C (118°F) [0x30] (GPU Core 4)
"Cooling Retail cooling"
Do you mean stock heat sink?
Your temps are pretty close to each other and not too high so no worries there, buying an aftermarket heatsink -
http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-NC
http://www.overclockers.co.uk/showproduct.php?prodid=HS-060-TR
Either of the above will knock a good few degrees off your cpu temp, if your that bothered about the graphics you could look into aftermarket coolers but they may not be worth the effect, just make sure your system has good airflow (good cable management helps).
That looks a pretty mean setup, and should be a fun overclocker :)
those temps look ok, but out of interest isnt there a lot of noise with that stock cooling?
i seen the lian case in action and with that sort of mega high spec i suprised it isnt like being in a jet wash.
like other guy said stick a good CPU cooler on and it will help a lot.
maiin areas are:
case
mangement of cables ect
fans
extras
as long as case and cables are good and properly done and tidy then heat can be optimal thoughout the case.
then it just a issue of fans and making sure tey doing their job properly.
extras are just things like CPU coolers/GPU coolers ect.
maybe post a picture of your system/case and that will give an idea of how well managed the case/cables are.
