Hi peeps! Its been a while since i last posted on this forums...so much has changed ;S
Anyways, straight to the point.
Ive just made a big upgrade from my Q6600 / 4GB ram / p6n32e SLi Plus setup to the setup described in my sig mainly for a huge boost in video editing / encoding. I didnt bother upgrading my gpu since i didnt find any real need. (This gpu is really good for this generation of games anyway, in my opinion)
Its the first real upgrade ive done myself...its more or less a new PC now. Im quite impressed with the results so far, everything is faster at just about everything.
I have been doing some video editing with it and when encoding, i noticed that the asus program was warning me that the temperature was going above 65 degrees and after 5 minutes of encoding, it was even reaching 90 degrees...that's worring me.
I have attached pictures of my rig as it is now. It might just be my messy cabling setup hahah. I have about 3 extra fans on the case itself (one at the back, one on the side and one in the front but the door covering the on switch us usually semi-closed...figured this didnt matter since there is quite a big gap under the door and between the hinges and side). But I was wondering, is it normal for this CPU to reach such high temperatures when it is under such processing / stress? If not, are there any good cooling solutions I can use to get the temperatures low? I have been considering a Corsair H50-1 but perhaps I am overworried n need a slightly better fan?
Another quick question, would it be possible to remove some fans if I was to get a better CPU cooler? I dont know why this system had so many fans in the first palce...perhaps that ebay seller I bought this from was over obsessed with rotation (too much naruto? ;p)
Any elite expert advice from all of you pros will be very much appreciated.
Thanks in advance.
Thanks in advance.
