I was thinking of purchasing an offer on Overclockers:
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz......
The only problem is with the fan, Noctua NH-U12P SE1366 CPU Cooler
(Socket LGA1366). I am fairly sure it will not fit into my case. The external
width of the case 18.5 cm. (internal measurement some what less)
I was looking at the Corsair H50 High-Performance CPU Watercooler (Socket
LGA775/1366) but this is not the correct socket number.
Can any one advise on a suitable cooling system within a similar price region
of £60.(or below) that will fit?
