Hi, I currently have the Coolermaster CM-690 Dominator Nvidia Case using just the original fans in the original flow direction (black). I'm thinking about adding two 120mm top mounted fans (red) to direct more air into the case. I'd just like to know which fans should be pointing were for optimal airflow and cooling. Thanks
