cooling help
16 Dec 2008
tomorrow i am going to try an lower my twmps going to buy new thermal compund(silver) maybe lapp my cpu.
would it make a differance if i cut a hole out of my case with a dremal behind the cpu faceing the back of the motherbord onto where the cpu would sit blowing air on the bord ?
^would that be worth doing ?
could some1 tell me if i would be wasting my time thanks.
and or any gd little tips wich could help me cool my pc
thanks.
It would help to cool the back of the motherboard and probably the VRMs which would mean that you MIGHT be able to push your oc'ing antics a little further. Might shave a few degrees off your CPU temp.
If you do this make sure you have a filter on the fan or you'll get a build-up of dust right where you don't want it.
