cooling loop?
20 Apr 2008
Nr Liverpool, Uk
hi
my cooling loop consists of
Ek supreme hf full nickel
XSPC Laing DDC Pump Top Reservoir
Alphacool NexXxos Xtreme II Rev2 Double Radiator
an works nice with my i5 temps are 35-40 idle
looking at buying 2 x 670 graphic cards for sli
now i can get pov ones with or without waterbock already on for the same price but thinking would this mean i would have to add another rad or could i get away with just putting them in the current loop :confused:
do you have room for a thick 120 anywhere? Added to the loop it should boost the cooling enough to just about cover the 670's... Although if you have good airflow in your case you should be fine running them on air.
