hi there lads i bought a Ultima Vanquish from overclockers and after a lot of gaming my room turns to an oven, there is 1 fan for intake and 1 fan for outtake as far as i no there is only 1 more fan slot which i was going to put an intake in. Or would it be best for me to mayb go to watercooling? as i said my room without a window open after mayb a couple of hours of gaming gets a little uncomfortable.
A mate of mine also said something about a radiator which you can put into the pc which absorbs the heat?
which one would u recommend many thanks
I just keep my window open in summer when I'm gaming
