Having recently picked up a 3070FE I'm finding that the end blow through fan is generating a pocket of really hot air for my ram to sit in.
Case is made from an old motherboard tray, a couple of extra bits bonded to it for strength and screwed to the wall. It's completely open and generally very good with thermals.
https://photos.app.goo.gl/7ct7GwD3izFFkCP86
The 150mm thermalright fan is blowing cold air into the pcie slots, behind it is an Intel pcie nvme drive and 3 SATA disks. It also acts as a feeder for the top GPU fan.
The CPU cooler is currently blowing downdraught so it's not pulling hot air from the GPU. This is then compounding the ram heat issue.
The ram is only 3200 running on the xmp profile without any other overclock but after running the GPU at heavy loads the heat spreaders are almost too hot to touch, guessing about 50-60 °c.
Would I be best trying to deflect the flow from the GPU outwards with a heat shield, use an active solution to pull the air out or push cold air in and let it just disperse the static air?
Any thoughts? With my old 1070 it was never a problem because there was no blow through.
