Cooling with TT Armor
7 Oct 2004
Hey
I have a full TT Armor case, there is a 120mm fan over the HDD bay, but it fits into the HHD removable bay itself, can i fit another 120mm fans below is to i have 3 intake at the front, i run Dual SLI 8800GTX's and with summer moving in, its getting slighty toasty in there.
Or has anyone got any other suggestions on how to mount 2 fans to the front of this case....
Thanks
The easiest way is to buy another drive cage, which has the attachment for another 120mm fan
There is another option. Thermaltake do a side panel with a 25cm fan in it. They are a bit hard to come by but do wonders for the whole system temp.
Easy enough to hang another 120 fan onto the front one using cable ties. Gets better airflow that way as cage isnt in the way.
