laiman said:I would assume that it can be done using a usb flash drive, haven't done any game saves but I know the 360 reads files that are on my flash drive no reason why t5he reverse won't work.
Aspect said:Could you plug the HD directly into the pc with a usb extension cable?
Memphis said:The 360's hard disk is not USB, it uses a laptop SATA disk. The next hurdle is the proprietary file system used. It can be read through a Linux OS after quite a lot of fiddling but for the effort required, you may as well just accept it's not possible.
Memphis said:There is a very good reason why it won't work.
Microsoft has not included write support on the 360, apparently for security reasons. It's what is stopping us transferring PGR3 photos to PC.
