Copying unique values from a list using VBA - help!
23 Apr 2007
Cardiff-ish, Wales
Hi guys,
I've got a list that will grow over time (Dynamic Name Range = UserName). I'd like to be able to copy the unique names to a number of different columns and different sheets eg Sheet1 Column E, Sheet 2 Column E, Sheet 3 Column etc. I've also given these places dynamic named ranges e.g. Sheet1UniqueUserName. Sheet2UniqueUserName etc.
I've found a bit of code that copies the unique names to the last column on the sheet and it works well:
Sub UniqueList()
'Populate control with
'unique list.
Dim LastRowcell As Range, LastColCell As Range
Set LastRowcell = Cells.Find("*", , , , xlByRows, xlPrevious)
Set LastColCell = Cells.Find("*", , , , xlByColumns, xlPrevious)
If Not LastRowcell Is Nothing Then
Range(Cells(1, 1), Cells(LastRowcell.Row, 1)).AdvancedFilter _
Action:=xlFilterCopy, CopyToRange:=Cells(1, LastColCell.Column), _
Unique:=True
End If
End Sub
How do I change the location of the unique list to the ranges that I've mentioned, on different sheets?
Cheers,
Jed.
