Cordless combi drill
14 Mar 2005
Here and There...
Looking to buy my dada a decent cordless drill as his has packed up, I've set myself a budget limit of £100 ideally less! He was very impressed with the hitachi I picked up from screwfix when they were on offer last year so I was hoping for a similar offer but so far nothing!
Today I saw this on the screwfix site and thought it looked spot on under budget, decent brand, two batteries http://www.screwfix.com/p/bosch-gsb18-2-li-plus-18v-1-5ah-li-ion-cordless-combi-drill/9647j
Anyone seen anything else out there in the sub £100 bracket ideally with two batteries that is worth considering?
My parents bought me a Bosch PSB 1800 LI-2 to replace an old NiCd battery Bosh Drill that wasn't holding its charge. This thing is amazing. I installed a projector and brackets over the weekend and it drilled 10cm into the solid wall with ease. Something my older one had trouble with. 2 batteries, Li so holds the charge and about £80 if you shop around.
my money would be buying something from Bosch, Dewalt or Makita.
That one you linked to only has 1.5Ah batteries so they won't last as long but you can at least charge one whilst using one, can't get my head around wether or not 1 x 3.0ah is better than 2 x 1.5ah. probably the latter.
The Ryobi drills are really good for the price, I have a Makita and had a Ryobi that I gave away and regret it now as it was a great drill, better than the Makita.
I bought the GSB 1800 2x2Ah from screw fix a few months ago and it has been faultless so far. Looking at the specs the GSB 18-2 and GSB 1800 are almost identical so would hope it is equally as good. Not sure if 2 x +0.5Ah is worth an extra £20. If you are using the drill up a ladder/above head height often then the lighter 1.5/2Ah battery are definitely preferable to the 3/4+ Ah. Also if the single 3Ah battery runs out then its run out, if you have 2x battery you will hopefully never run out of charge provided you keep one on charge whilst using the other.
Makita all the way. Got one for xmas and it is the best drill i have ever used, nothing has compared. It drilled through accrington brick like it was butter and never ran out of charge or slipped. The only problem is that it has made me want to buy more makita tools lol
My dad isn't getting any younger so I thought the reduced weight would be good for him and he can always have the other battery on charge while he's working
I picked up a Haitachi from Screwfix a few months ago for £70 IIRC. It has been flawless.
Wish I'd got two I'm really pleased with mine for the money I was hoping the January sales might see a similar deal but sadly not!
Some interesting prices on the GSB1800 was surprised to see the 3Ah model cheaper than the 2Ah.
There are so many different models it's a nightmare trying to make a decision just need to pick something and buy it now so I can forget about it!
I think the common consensus from the last thread was that the Dewalt, Bosch, Makita etc at this price are all about the same and you should go with your personal preference.
Go for the Bosch (blue not green)
I have several Bosch drills and they are the mutts. My Bosch 36v SDS drill fell off my roof bounced on scaffolding then hit the floor.....I was worried i may have broken my floor.....Drill perfect....its like a kango
