. i like the case... really slick, and hardware installation isn't a problem... considering this system was my first build i found it pretty painless... except, i was a noob and not aware you can remove the front bezel so i cut myself removing one of the panes installing the CD drive... but aside from mounting the mobo in and fitting the I/O panel, it's pretty easy to do, and roomy enough, i'd say... Hi I can only afford a E2180 conroe 2.0 at the mo would it be better to go for single core and higher MHz if you want gaming performance?
