Tooks said:Is your room very cold?!![]()
I'll try the new Core Temp as suggested aswell then.Sean_UK said:Nope, my indoor weather station suggests 24.7c![]()
Sean_UK said:Room ambient to inner case ambient will differ, but yes does sound odd.![]()
Tooks said:As long as it's stable, then what does it matter!![]()
Mobo a bit toasty with that passive cooling.
Jono8 said:yeh im getting similar temps to you
)Tooks said:Dpn't keep meaning to rain on folks parades, but there is just no way that those temps can be right either...![]()
Two wrongs don't make a right, unfortunately.
As I said, whatever the reported temps, at least you've got a baseline to work from.
The only way you'd get temps less than ambient is with phase or similar. (Somebody else come in here please!)
surely if there is good airflows and the fans are blowing a lot of cold air onto the heatsink its very feasible that its goes below ambient temperatures
Proof that the sensors are wrong!heres proof:
