Guys,
I recently got myself a new C2D rig. Its a 1.86Ghz Chip with an Asus P5W DH motherboard and an Artic Cooling 7 Pro jobbie on it. I am trying to keep the noise of the computer down to a minimum so I originally went with :
The CPU Cooler (1fan)
GPU Cooler (1fan)
Enermax PSU (2fans)
1 Out-take 80mm Fan (1fan)
With this setup my idle CPU temp was about 31degress (using Speedfan).
Lately one of the fans has started making a god awful noise - really bad high high pitched noise that really gets on my ****. I thought it was the Artic Cooler that was playing up. Just to be sure though I disconnected the 80mm sunon outtake fan. When I repowered my computer, i could hardly hear the computer. Its perfect. I would love to be able to keep it like this.
However!
My idle temperature has gone up 10 degrees. Idling at around the 40degree mark. I am currently stressing the CPU to see what the load temps are like and currently it is at 61degrees (again in speedfan). When I load up Everest though, that will show me the temperature of both cores - which are at around 75/76degrees - but I am assuming that core temps are always going to be a lot higher and its 61degree one I should be watching?
So are them temps safe or do I need a blow o ut fan on the back? I cannot go back to using that sunon fan cause of the noise it makes. If you think I need a blow-out fan, can someone suggest a VERY LOW noise 80mm fan? It needs to be 80mm as that is what my case takes. Needs to be one without any dodgey wirring noises or high pitched noises.
Thanks.
Stuppy
GPU Cooler (1fan)
Enermax PSU (2fans)
However!
Thanks.
Stuppy
