Core i7 1136
26 Jan 2006
Hello all,
I got a Core i7 1136 socket, 12GB DDR3 6x2GB, and ATX PSU but no motherboard and case that I would like to "revive".
As I moved to a more "tidy" lifestyle :p I need a setup that is small, minimal, and quiet. Any ideas on case/motherboard for the above components? Also, is it worth it reviving the above or for same cash I can get similar/same performance with latest components.
Thanks a lot for suggestions!
PS: I noticed OCuk stocks limited 1136 hardware :(
As the Mantis said, you're going to want the Rampage III Gene.
Then simply select the microATX case of your choice. Some suggestions:
- Antec Mini-P180.
- Lian Li V350, V351, V352, V354.
- Silverstone Sugo SG01, SG02, SG03, SG04, Temjin TJ08.
- InWin Dragon Slayer.
Note though, that some of the above cases will not take the very biggest graphics cards, so research sizes and the like if this is important to you. You can find case dimensions here:
https://docs.google.com/spreadsheet/ccc?key=0AqsHvPQdD3R9dDAwc0NyVlFDQW9kLUEtempmU0ktUXc
Any more questions, just ask. :)
Thanks all!
I think ASUS Gene II as I will run SSD for system drive. I ll look to source one. Storage is via 1Gbps link to the synology raid mirror box so SATA 6Gbps is redundant.
For cooling I will look at the all-in-one water solutions as they are cheap and quiet nowadays.
All that remains is to find a case ... I have an old radeon card I could use but is slow and way big for what it can do I think. I guess a cheap low end model of the current ATi/nVidia range (50-60 quid?) will do the job ...
