- 28 Dec 2017
- Beds
Exactly my reasoning with epoxy. Just a dab on each corner, sharp knife will slice through it. The gasket stuff seems a bit heavy if you use it all over. Plus I already had epoxyI've only done a few delids, but I used just a spot of super glue in 2 opposing corners. That way if you want to take if off again a little acetone or fingernail polish remover will easily dissolve it so IHS can be removed easily.![]()
![Wink ;) ;)](/styles/default/xenforo/vbSmilies/Normal/wink.gif)
