Hi, bought an i7 CPU with intentions to overclock it to 4.2ghz. I have a Noctua NHU-12P Se1366.
Asus P6t Deluxe
Patriot Viper 6gb DDR3 1600mhz (8,8,8,24)
Core i7 920 D0
I try to OC the CPU to 4.2ghz but I always fail the stability tests in Prime95/Linx because my PC blue screens. Here are my Bios settings:
CPU volt: 1.31250
QPI/DRAM: 1.36250
CPU PLL: Auto
DRAM: 1.64
My timings are at 8,8,8,24 at 1600mhz
All other settings are on Auto.
Does anyone know why my PC blue screens in the stability tests? Is there an option in the bios other than the voltages that I am supposed to change?
Any help appreciated!!! The whole reason I bought this CPU was to have 4.2ghz
Also my bclk is 200 with a 21x multiplyer.
EDIT: I upped the voltages on cpu and qpi a notch or two and I ran prime95 small fft, but after an hour I got a blue screen
Also my temps during the test maxed out between 83-87c is this acceptable?
Asus P6t Deluxe
Core i7 920 D0
CPU volt: 1.31250
QPI/DRAM: 1.36250
CPU PLL: Auto
DRAM: 1.64
