Core2duo in Zalman TNN-300
20 Jul 2006
Just want to know since the case can handle the heat output of the cor2duo, and you can get MATX core2duo boards, will the CPU heatsink in this case attach to socket 775 boards?..., no word from zalman, they just say it cannot handle the heat ouput of socket 775 cpu's, but no mention whether the cpu heatsink will fit on the boards/socket..., am i right in thinking that when you remove the retention bracket from a socket 478 board then it will be the same as a socket 775 board?..
No. They are slightly different spacings.
i would have thought if the socket and chip sizes are different then the holes would be as i dont think there is a standard mobo layout for the holes - but i have been wrong in the past
They are not compatible otherwise they wouldn't make special LGA775 coolers, they would just supply S478 mounting brackets to adapt your old cooler. The sockets are not the same and the holes are a different spacing. Sorry.
Reason they make Socket 775 cpu's is casue the 478's have a retention bracket..
When Intel redesigned the socket from 478 to 775 pins they changed the socket in lots of ways. They put the pins on the motherboard, they changed the physical dimensions of the array and they changed the dimensions of the motherboard mountings.
If all it took to change a 478 cooler to a 775 cooler was to add the retention bracket, there would be a healthy market in new and second hand P4 retention brackets. There isn't. Because the sockets are physically very different.
Anyway - just to kill this once and for all - the OP question was can I fit a S775 motherboard in this case?
The answer is yes - http://www.zalman.co.kr/eng/product/view.asp?idx=177&code=020
if you look down the page there is a list of supplied parts and underneath the S478 retention mechanism is the S775 retention mechanism. Now why would they supply 2 mounting mechanisms if they were the same size? :rolleyes:
As Core2Duo's run as cool as AMD 64's I would say it will probably work just fine.
cause the capacitors are in the way... :p
Yewen said:
Have no idea whats going on in this thread.
I attempted to help someone. That's all. Now they are apparently calling me a spoofer. No worries. I won't make the same mistake again.
WJA96 said:
Thanks, hopefully the contents list is right, will order sometime soon, but If I don't get the Socket LGA775 Plate as advertised, will I get a refund for the case?, and I hope I won't have to pay return shipping... If I order from OCUK I mean, might be better ordering off an official Distributor?reseller though.., as heard OCUK are not the best for returns...
My Bad, just that I have been looking forever for an answer, posted on the Zalman Forums, and all they say is that there are no Core2duo MATX boards available, replied with a list of 10 I could think of but no answer..., thanks for the help..., suprised no ne has thoguh about building a core2duo build with this case, could easily get a silent Viiv Machine, which uses little power..
