I'm new to this not started overclocking yet so everything still at stock, so why the big difference in core temps between the two?
Speedfan v4.33
Core 0 - 31C
Core 1 - 31C
CoreTemp v0.95
Core 0 - 47C
Core 1 - 46C
Which one is correct?![]()
TAT, Coretemp and Everest all give the same results for me, Speedfan is the only one that shows a 15C temperature difference. So speedfan just needs adjusting, its designed that way.
Get this when I try to run TAT v2.05?
"Error enumerating On Demand Clock Modulation support. Terminating Tool"
Is that right? I thought the difference was due to the fact that CoreTemp and TAT read the temps straight off the die, while Speedfan reads it from somewhere off the edge (and hence appears cooler).
as I can't seem to use TAT
