A friend showed me a very annoying puzzle with two wine corks. Apparently psychiatrists use it to see how mental you are (if you're mental, you destroy the corks in frustration, if you're not, you keep trying til you solve the problem).
I'll try and describe it:
1. Put a wine cork tucked in between your thumb and index finger, at the base of the 'v', one cork on each hand.
2. Bring your hands together and grab the cork in your left hand with the thumb and index finger of your right hand, and vice versa for the cork in your right hand.
3. Pull the corks apart.
They just get stuck!! I don't know how he did it!! I watched him do it really slowly and I still couldn't figure it out. The range of times he quoted for solving it was 30 seconds to 2 weeks, so good luck.
If you can understand my description, I'd be grateful if you could have a go. Btw, if you don't want to be frustrated for the rest of your life, don't even attempt it.
