Correct rawl plugs?
17 Aug 2009
Finchley, London
Hi guys. Started drilling holes to put up some coat hooks but the rawl plugs I have only go halfway in. Do you know what size I'd need?
The ones I have are red, and also brown.
The drill bit size is 6mm.
Just hold the drill bit against the plug (use the non-threaded part of the bit, it's easier to see) and match the width, going slightly under rather than over.
E:
Aren't you drilling wood there? Don't bother with a plug at all - just screw it in (drill a small guide hole)
Get some 6mm ones if you're using a 6mm bit also make sure you're drilling deep enough for them to actually fit and don't forget it should be a relatively snug fit.
You don't need plugs, some self tapping screws will do the job. If not pick up some spring toggles for heavier loads.
Well it seems I have to use plugs. Last night I tested drilling into a piece of wood with my smallest 4mm drill bit and the screws don't thread, they just drop in.
You need a smaller drill bit.
Or just use your 4mm bit and drill a shallow guide hole and let the screw tap it's own hole after that.
Yeah, I guess this is the answer, I'll get some 6mm plugs. The screws go all the way in the hole so I guess I've drilled far enough in. I'm a bit worried to drill any deeper in case I break through to the other side of the door.
A 6mm hole even with a plug doesn't sound like it's going to work if the screws drop straight into a 4mm hole.
Yeah, it seems I do need smaller drill bits than 4mm, then as you say, I shouldn't have needed plugs.
Ah well, since I've now drilled a 6mm hole, I'll try 6mm plugs. Or maybe I can buy screws that are wider?
I think the 6mm plugs might work though.
That's a door right? Is it solid or hollow?
If solid then just dig in a little with a bradawl and use a self tapping screw.
If hollow then I've always found it a bit trickier. gluing a baton on and then screwing into that is one solution I've seen, otherwise you'll need to see if there's something specifically for fixing into a hollow that is short enough. Many of the ones designed for plasterboard will be too long, but perhaps something like a small spring toggle fixing would be right if short enough:
http://uk.rs-online.com/web/p/produ...|prd|5238963&gclid=CLT_9_-U-88CFVS4Gwod4RYDEQ
It's a firedoor. I started with a braddle, then a pilot bit (my 4mm) then the 6mm.
Actually, maybe I didn't drill far enough in yet? The screws drop all the way in the hole I made though without the plug. See, last night I tested the different size bits on a piece of wood and the red plug pushes all the way into the 6mm hole. So maybe I should drill a bit deeper?
Lol, I'm really quite hopeless at DIY but I do at least try. :p
Take your bit, line up the bottom of the plug with the end of the bit, wrap a bit of tape around your bit where the top of the plug is.
Then you know where to stop drilling.
This might give you a clue r sole :( -We all had to learn.
Thanks for the help guys. tom-e, I wrapped tape around my bit (ooh matron). Yep, I simply hadn't drilled deep enough. *facepalm*
All done now. Now to drill for the second hook to the right of it and two more for the bathroom. :) I'll buy 1mm to 3mm drill bits for future use so I don't have to use plugs in wood.
Yes cheesyboy, it was pushing it a bit. This is the length of the plug to the depth of the door. I guess I could have snipped the plug length if need be.
OK - no offense
To OP
If you are fixing into solid wood just use a wood screw - make sure it isn't to long if screwing into something with a finish on other side. - Also helps to drill a pilot hole but it must be smaller than screw - 4mm diam screw drill 1mm hole- Just also seen you have egg box doors so plug is needed.:rolleyes:
If you are screwing into hollow doors etc you could use a hollow wall fixing.
The same is said for fixing in plasterboard or other type of boards .
If drilling into concrete -brick or block you use a wall plug or wall fixing.
These are just the basics.
Hope it helps
ps - bit late now just saw your reply :rolleyes:
Heh, yeah, I'm slowly learning and improving :) Don't do much DIY at all but I'm enjoying using my new drill, drill bits and screw driver bits. I'm going to buy some screwdriver extensions as there's been things in the way when putting up my curtain pole and just now with this hook which meant using a manual screwdriver for some of the job.
