- 7 Aug 2003
- Bedfordshire
Hey everyone,
For the first time *ever* a Car I have owned passed it's MoT first time!!
I took it to the local Council Test Centre this time around and was relieved that it only costed £54.80.
I have spent the last few days checking a few things - made sure my seat belts were free of damage, made sure the retention mechanisms were working well, before checking the steering wheel, door mirrors and door locks.
After this I took a good look around the vehicle and found out that a reverse light was dim - I subsequently found out that one bulb was 24v instead of 12v. Heaven knows how that got there. I also replaced the dead registration lamp from my Escort and Corsa spares.
Today, I checked all the tyres, made sure the bearings were good - packed them with new grease as the grease was looking a bit old and renewed the split pins before ensuring the suspension components were free of damage, corrosion and leaks.
So for £650, an oil & oil filter change and 2 new belts, my Corsa has done very well indeed!
I had three advisories - there is some corrosion on the inner sill (fix that with angle grinder and rust convertor) some corrosion on the master cylinder/servo (a design flaw apparently) and one of my exhaust mounts has failed.
I got a couple of new exhaust mounts this morning (didn't get a chance to fit them before the MoT as the exhaust was too hot) which were only a few quid. Once it all cools down I can get that sorted as well as sorting the corrosion out.
I think it will be good for another MoT as long as I get those bits sorted and I keep on top of the oil & filter change.
Well happy
Got my Spitfire this April to MoT, so that will be interesting!
Kind regards,
Well happy
Kind regards,
		 Just booked mine in for it's MOT, along with a huge check-up by the top mechanic. I shudder to think of the amount of things they'll probably find wrong with it.....
