Hi
I have a Corsa SRI 1.4 – its currently in the garage for MOT, it’s also in due to it misfiring. The guy at the garage has plugged it in and its coming up with a problem on cylinder 3 and its going into limp mode. Ive used this mechanic quite a few times so ive no doubt in my mind he is spinning me a line or anything.
He has suggested putting new oil in it and give it a clean as he thinks a valve is sticking but I don’t feel confident this is the problem. I asked a friend of mine to put a new coil pack and check the plugs are ok and he said its fine (this was before it went into the garage). He said if this doesn’t work he would be inclined to strip it down and have a look, but this would have obviously £££'s... I don’t have the money to chuck at it and would like to get a quick fix asap to be honest.
Has anyone else had a similar with these cars? If the new oil and filter doesn’t fix it does anyone know a decent mechanic in or around Oldham/Manchester who could help me with it?
Cheers
R
Cheers
R
