It's probably the throttle cable hasn't been refitted properly. Get someone to press the pedal to the floor(with the engine not running) while you look under the bonnet to see if its reaching full throttle opening. If not then just adjust it.
Although I don't like Novas/corsas, I really liked the Isuzu TD powered ones.
Yea, I mean the skirting around the arces. I think there is a thin peice at the bottom of the door, apart of the chassis, that is black. But the bottom of the door is blue to me.
i am well impressed and quite jelous! well done mate. it ownt let him down, tho do consider cxhanging the glow plug becouse when they do stop working you will be swearing
