Ok Im back at it again ... saw this case here
https://www.antec.com/product/case/df600-flux.php
IMO its a nice looking case even if its cheap. The front rgb fans look good when you can see them. Only problems with this case thou from what I read - the fans are not pwm and they are Really loud.
oh and check what I found ...
https://appsbuilders.org/news/corsa...modate-huge-graphics-cards-up-to-420-mm-long/
there was a small article on techpowerup but it got pulled - looks like they are coming out with a bigger 4000d - but it looks a bit big ie here are the dimensions of all the cases Im considering.
phanteks 500a hwd 510 x 240 x 505 mm
corsair 500d se hwd 507 237 500
antec df600 flux hwd 486 220 467
Corsair 5000d airflow 520 245 520 (HxDxW)
Corsair 4000d airflow 453 230 466 mm
Corsair 450d (current case) 494 210mm 497mm
a bit on the big side - compared to my current case. Im thinking they might update their 500d rgb line at somepoint.
anyways some more food for thought ...
