Corsair 540 White - 2nd Built with previous parts
31 Mar 2013
Essex/london
YOUR BASKET
1 x Powercolor Radeon R9 280 TurboDUO 3072MB GDDR5 PCI-Express Graphics Card £199.99
1 x Asus Crosshair V Formula Z AMD 990FX (Socket AM3+) DDR3 Motherboard £169.99
1 x BenQ GW2450HM 24" Widescreen LED Professional Monitor - Black £149.99
1 x AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz (Socket AM3+) Processor - Retail £143.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Arctic White (CC-9011048-WW) £104.99
1 x Seasonic G series 750w '80 Plus Gold' Modular Power Supply £99.95
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £88.00
1 x Crucial M500 240GB SATA 6Gb/s Solid State Hard Drive - (CT240M500SSD1) £85.99
1 x Plextor M5 Pro 128GB Extreme Series Solid State Drive - (PX-128M5P) £84.98
1 x Avexir Core White Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CIW) - White Light £71.99
1 x NZXT HUE RGB LED Controller - Black £39.98
1 x Corsair Raptor K30 Gaming Keyboard (CH-9000043-UK) £37.99
1 x Corsair AF120 Quiet Edition Low Noise High Airflow - Dual Pack (CO-9050002-WW) £22.00
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £22.00
Total : £1,344.74 (includes shipping : £19.10).
Ive decided to do some shopping and use some of my old parts and I still need to get rid off some of my old stuff: MSi r9 270, Motherboard and etc.. but the above should be the final spec with the parts coming in tomorrow :D
As for the future ill probably add another r9 280 and change the PSU when the time is right, braided cables maybe white ones? Im still not sure whether to use my old fans as the corsair white one comes with nice af140 with white leds unless I can do push and pull. I also plan on adding storage and going dual monitor set up!
Anyways opinions and thoughts on the built, whats missing and etc is welcome - pictures should be taken tomorrow when I have everything
As much as I like Kingston I'd reccomend looking at the Samsung 250GB SSD 840 EVO for the SSD.
The stock fans with the 540 are a bit noisy but they do push a ton of air so depends whats important to you.
I think ill give the fans a test and see how it goes but I already got the fans to replace them if im not happy with them, as for the Kingston and Samsung I was mainly going for speed/price and kinda fits the black/red/white color scheme
Shouldve taken this on board as im now going to return that Kingston ssd because the write speeds are nowhere near the 450. I will be getting the Crucial m500 now
Yeah sucks they seem to have changed the NAND on the Kingston :| didn't realise the speed hit was as big as the other thread showed.
Motherboard:
You have no idea how sexy and high quality this MB looks!
CPU:
Better look:
PSU:
Push and Pull Set up:
I managed to take the fan filters from my bitfenix ronin and added it the top and bottom of the cage here is an example:
with the top fan filters are you not keeping dust in? building it up in the rad? i thought you never put filters on exhaust fans? maybe im completely wrong :)
Will remove it then. need to install the NZXT HUE now but gonna have to be creative as the cable is no longer sticky as i removed it from my bitfenix ronin. Also what you guys think of side fan? ive changed it from exhaust to intake. im so tempted to get 2x120 AF white leds and 1x 140 AF white leds - but then ill have 3 times 120 AF laying around and those fans aint cheap!
i still think they couldve been more creative with the bottom part of the cage... looks empty with ssds and being open just means dust inside the case, wouldve been nice if couldve set up bottom fans
Agreed. Could always borrow a dremel, cut out fan holes on the bottom, and use this underneath:
YOUR BASKET
1 x Silverstone SST-FF142B Magnetic Fan Filter - 320x155mm £5.99
Total : £8.96 (includes shipping : £2.48).
I'd probably do this if I had that case, to complete the look.
im using the bottom fan filter from bitfenix ronin, since its magnetic too it does the job, any input wether to make the side fan an intake or exhaust?
