It's not removable in the case of the 800D. Unless you want to start de riveting the case, but after paying £200 for a case I don't really want to start de riveting my case . The 800D really doesn't require a removable motherboard tray though seeing as there is so much room to work with in the case, also the fact that there are so many holes in the case for cable managment would probably cause issues (vibration/flimsyness) inside the case if the motherboard tray was removable.
Leviathan may be talking about the COOLERMASTER ATCS 840 which does have a removable motherboard tray.
