Only thing guaranteed from side fan is that it affects lot to airflow pattern inside the case... often just messing it up:
http://forums.overclockers.co.uk/showthread.php?t=18045074
Situations where it helps is when there simply isn't good existing airflow (=any extra airflow helping) or it happens to fit to overal airflow.
Yes...I take your point and I've always avoided sidepanel fans until now...but airflow pattern in my opinion (front fan in, top rear fan out) is only upset if there is sufficient airflow from the front fans getting through to the rest of the case in the 1st place...I believe the CM 840 in stock form has the drive bays turned sideways so most of the airflow from the fan doesn't get past the drives. You are relying mainly on the top exhaust fans. There is no windtunnel effect to begin with. I have seen a couple of reviews which criticized the 840 case over this when it came to gpu cooling. Their position was that the case was using negative airflow (3 exhaust fans v 1 intake blocked by hard drive bay) and they maintained positive airflow would be much more beneficial to cooling hot gpu's. *plus less dust as you are not sucking air through every nook and cranny* Apparently that's why the HAF is so good (which also has front airflow blocked by the hard drive bays). The sidefan helps the GPU temps according to bit-tech, and when they reviewed the 840 they blamed poor gpu temps due to lack of said side fan. Of course I realise having a side fan can still upset the cpu cooling and the natural order of things, but for brute force cooling your gpu's, I think a side fan can be very beneficial.
http://www.bit-tech.net/hardware/cases/2008/10/16/cooler-master-haf-932/4
i have a corsair case with core i7 920 idles @ 34.31.35.29 with a corsair H50 cooler gets to a max of about 49C while gameing
