Hi,
I have being using the Corsair AIO's since first released (H50/80?) and had no problems with.
Now I have being using the H100+ releases they seem to break quite quickly. I have had 3 in the past year and all have had the same problem ... the pump breaks.
Currently I have the H115i (bought about 7 months ago) and now I have the same problem, my idle temps sit about 50 degrees & max temps are low 90's. (Before max temps were mid 70's) .. The Corsair logo keeps flashing red (which I believe is due to the liquid reaching a certain temperature)
Can anyone suggest any alternatives? ... main PC use is the odd game & video encoding.
Spec
5930k @4Ghz
16GB Corsair DOminator
MSI 390x
Asus Strix X99
5x Noctua 140mm Industrial Fans (2x intake, 3x Extract)
cheers.
Spec
5930k @4Ghz
MSI 390x
Asus Strix X99
cheers.
and I was told about this Maelstrom 120K on a push/pull setup and my temps are great 55c under load gaming and it idles at 25c.
