I'm changing cases to give me more room to watercool in the future to a lian-li twin chamber midi tower. PSU I have is a AX760.
Spec is:
MSI Z97 gaming 7.
4790k clocked to 4.7ghz at 1.29v, can do 4.8 but temps rise quickly hence the want for full loop.
Zotac GTX1080 AMP! looking to upgrade to a GTX1080ti shortly.
2x Kingston hyperX 2400mhz 8gb ram, looking to add another 2 shortly.
2x 500GB SATA SSD's.
1x 4GB 5400rpm SATA HDD.
Corsair H105.
I was looking at installing 6x corsair 120mm red LED fans, 2x 80mm exhaust fans and a ek d5 pump.
Would my PSU provide enough current or do I need to upgrade? I've used a PSU calculator which suggests I will use 822w and should spec a 1600w PSU to remain efficient which is mega excessive in my opinion. What are your thoughts?
Spec is:
MSI Z97 gaming 7.
Corsair H105.
