Hi I have the above case and want to optimise the cooling. Currently just has the default fans: 2x 120 front intake, side 240 intake, top rear 120 exhaust. Case has mounts for 2 120/140 top fans and one bottom. Any recommendations for mid range fans and whether any of the defaults should be replaced? Would also appreciate advice on the fan configuration and whether any more than what I've mentioned should be added. My cpu cooler is nhd15, gpu is gigabyte Gtx 770. Cheers.
