Result. Saves you the hassle.
thanks for your help my next step was taking the front panel out of my 540 to see if that ok
Mine at the mo,no power house just a tidyish build.
When funds become available would like to stuff an XSPC AX360 White Rad in the front and some new fittings.
Thanks for looking![]()
Petey, how much rad space have you got in your setup?
Are those temp monitor readouts on the GPUs?
Hey guys,
I need some advice and help on modding my case with a colour theme.
I've just bought all the parts for my built but want to go with a good colour theme/lighting and need some advice from you guys on what fans etc I should go for.
My motherboard is orange... so I would probably have to go for red, although I wanted to go from a lime green initially
Could someone recommend a fan controller and fans and what not for me please. Here's my build:
1 x Intel 5960X Extreme 3.00GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75960X) £869.99
1 x EVGA GeForce Titan X 12288MB GDDR5 PCI-Express Graphics Card (12G-P4-2990) £899.99
1 x Gigabyte X99 SOC Champion Intel X99 (Socket 2011) DDR4 ATX Motherboard £218.99
1 x Kingston Predator 16GB (4x4GB) DDR4 PC4-21300C13 2666MHz Quad Channel Kit - Black (HX426C13PB2K4/16) £215.99
1 x Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU) £164.99
1 x EVGA SuperNova G2 1000W '80 Plus Gold' Modular Power Supply £134.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £114.95
1 x Corsair Hydro H100i GTX 240mm High Performance Liquid CPU Cooler (CW-9060021-WW) £101.99
1 x Western Digital Caviar Red 3TB SATA 6Gb/s 64MB Cache WD30EFRX - OEM HDD £92.99
http://forums.overclockers.co.uk/showthread.php?t=18667099
I haven't bought a cable kit yet as I wasn't sure what colour to go for.
Any help is appreciated
Thanks
I have the same MoBo colours as you. I had installed orange tubes previously, but I've settled on white and chrome as I think it's just a better look overall.
http://forums.overclockers.co.uk/showpost.php?p=27895209&postcount=1405
