Corsair Force 3 SSD Help
26 Jan 2009
Hull
Hi all just wondering if any of you awesome people could help. I've purchased a Corsair SSD, it was working fine to begin. What happens is that when i try to start up windows(7) it gets stuck by the logo screen. I've tried to reinstall windows, it'll work fine for a bit but then it'll just do the same thing over. Any clue what it could be?
Much Appreciated
Sure here are the specs
CPU - i5 2500k
Mobo - Asus P8P67 pro
Ram - Corsair 8GB Vengeance 1600MHz
PSU - 700w
Its not overclocked and i have updated firmware
does it reboot or just freeze at boot sceen? are you set to ide or ahci mode? if you updated bios in ahci mode it will switch back to ide and might freeze/reboot at boot screen ect
