i have an average tower cooler that is currently only possible to use the fan fitted in pull as otherwise the ram is in the way of the mounting.
since i went to a 980 gpu that is not blowing the heat out the back of my case the cpu is running a good few c warmer. this is causing the fan(s) to ramp up to almost full speed when being pushed.
the way I see it is the closed loop water gives me the benefits of large surface area for the cooling without the hassle of custom water and having to spend so much time with tubing pumps and air bubbles etc. i did have a water cooling kit ~ 7 years ago and did have fun drilling up and mounting it all, but I'm older now and have the cash to throw at what i see as the neatest solution.
putting it all in a new case with space and good fans I will get a cooler gpu and a cooler cpu.
Im not planning to keep the internal dvd drive either, so that will be more internal space as well. so just an ssd, 3.5" hdd and a couple of pci cards and ill be all set. (tv tuner and sound card)
this will be a project for me next weekend I'm hoping, will order it for delivery Thursday I hope
Dan
Dan
