CORSAIR HYDRO H70 CPU COOLER - IN STOCK (BENCHMARKS INSIDE)
Will they ever bring out one that can do both CPU and GPU??
I guess there would be no easy way of supporting all the different GPUs... you'd end up with a dozen GPU adapters... still would be great if there was one.
I just cant get what I was once told out of my head... Water + Electricity dont mix
H50 temps for comparison.
Tested on the same rig cooling the 980X. Using the Single 120mm fan supplied with it/
Idling on desktop. 4ghz 1.344vcore
Folding 4ghz 1.44vcore
Prime 4ghz 1.344vcore
Quite abit hotter, you can really see the improved rad size and extra cooling taking effect in the H70.
H70 push/pull Vs H50 push
why not do a H50 push/pull with the H70 fans? id like to see that test. :)
because most if not all people who buy this will want to run push/pull so i think it would be fair no?
NathWraith - have you try tested out sample of CoolIt Eco A.L.C. 240mm Radiator CPU Watercooler yet ? I think this one could easy beat the H50/H70 overall.
bulldog, thats your 980X running at 4.5ghz up there by the way :rolleyes:
nice clock Nath
