**CORSAIR HYDRO X SERIES CUSTOM WATERCOOLING PRODUCTS**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
Corsair are well known in the industry and possibly one of the biggest AIO cooler suppliers in the UK. Over the last couple of years they have been working in the background on creating parts to enter the custom water cooling market. We have seen bits and bobs shown online and at the past few computex events but it is now coming to the market to buy.
Launch will have a few lines in stock and the rest coming over the next couple of weeks.
CPU Blocks (2 Options Available)
Corsair Hydro X Series XC7 RGB Black CPU Water Block - 115x / AM4 (CX-9010004-WW) @ £69.95 inc VAT
CX-9010004-WW, RGB Compatible Lighting, Suitable for Intel 115X and AMD AM4 Sockets, Black Design, 3 Year Warranty
Only £69.95 inc VAT.
ORDER NOW
Corsair Hydro X Series XC9 RGB Silver CPU Water Block - 2066 / TR4 (CX-9010001-WW) @ £74.99 inc VAT
CX-9010001-WW, RGB Compatible Lighting, Suitable for Intel LGA 2011/2066 and AMD TR4, Silver Design, 3 Year Warranty
Only £74.99 inc VAT.
ORDER NOW
Graphics Card Blocks (2 Options Available)
Corsair Hydro X Series XG7 RGB RTX 2080 Founder Edition Water Block (CX-9020002-WW) @ £144.95 inc VAT
CX-9020002-WW, 2080 Founders Edition Compatibility, RGB Lighting, 3 Year Warranty
Only £144.95 inc VAT.
ORDER NOW
Corsair Hydro X Series XG7 RGB RTX 2080Ti Founder Edition Water Block (CX-9020005-WW) @ £144.95 inc VAT
CX-9020005-WW, 2080 Ti Founders Edition Compatibility, RGB Lighting, 3 Year Warranty
ORDER NOW
Radiators (9 Options Available)
Corsair Hydro X Series XR5 240mm Dual Fan Water Cooling Radiator (CX-9030002-WW) @ £54.95 inc VAT
CX-9030002-WW, Dual Fan Radiator, 16 FPI, Black, 3 Year Warranty
Only £54.95 inc VAT.
ORDER NOW
Corsair Hydro X Series XR5 280mm Dual Fan Water Cooling Radiator (CX-9031002-WW) @ £59.99 inc VAT
CX-9031002-WW, Dual Fan Radiator, 16 FPI, Black, 3 Year Warranty
Only £59.99 inc VAT.
ORDER NOW
Corsair Hydro X Series XR5 360mm Triple Fan Water Cooling Radiator (CX-9030003-WW) @ £69.95 inc VAT
CX-9030003-WW, Triple Fan Radiator, 16 FPI, Black, 3 Year Warranty
ORDER NOW
Pump / Reservoir (1 Option Available)
Corsair Hydro X Series XD5 RGB Reservoir / Pump Combo - 250ml (CX-9040002-WW) @ £149.99 inc VAT
CX-9040002-WW, 250ml Capacity, RGB Lighting, D5 Pump Included, PWM Control, 3 Year Warranty
Only £149.99 inc VAT.
ORDER NOW
Soft Tubing Fittings
Hard Tubing Fittings (8 Options Available)
Corsair Hydro X Series XF Hardline 12mm Black Fittings - Four Pack (CX-9052001-WW) @ £24.95 inc VAT
CX-9052001-WW, Hard Line Fitting, 4 x 12mm OD Fittings, Black, 2 year Warranty
Only £24.95 inc VAT.
ORDER NOW
Corsair Hydro X Series XF Hardline 12mm Chrome Fittings - Four Pack (CX-9052000-WW) @ £24.95 inc VAT
CX-9052000-WW, Hard Line Fitting, 4 x 12mm OD Fittings, Chrome, 2 year Warranty
ORDER NOW
Corsair Hydro X Series XF Hardline 12mm White Fittings - Four Pack (CX-9052006-WW) @ £24.95 inc VAT
CX-9052006-WW, Hard Line Fitting, 4 x 12mm OD Fittings, White, 2 year Warranty
ORDER NOW
Corsair Hydro X Series XF Hardline 12mm Gold Fittings - Four Pack (CX-9052002-WW) @ £24.95 inc VAT
CX-9052002-WW, Hard Line Fitting, 4 x 12mm OD Fittings, Gold, 2 year Warranty
ORDER NOW
Angled Fittings (14 Options Available)
Corsair Hydro X Series 90° Rotary Adapter Dual Pack - Black (CX-9055009-WW) @ £24.95 inc VAT
CX-9055009-WW, Black Angled Fittng, 2 Per Pack, 2 Year Warranty
ORDER NOW
Corsair Hydro X Series 90° Rotary Adapter Dual Pack - Chrome (CX-9055008-WW) @ £24.95 inc VAT
CX-9055008-WW, Chrome Angled Fittng, 2 Per Pack, 2 Year Warranty
ORDER NOW
Corsair Hydro X Series 90° Rotary Adapter Dual Pack - White (CX-9055014-WW) @ £24.95 inc VAT
CX-9055014-WW, White Angled Fittng, 2 Per Pack, 2 Year Warranty
ORDER NOW
Corsair Hydro X Series 90° Rotary Adapter Dual Pack - Gold (CX-9055010-WW) @ £24.95 inc VAT
CX-9055010-WW, Gold Angled Fittng, 2 Per Pack, 2 Year Warranty
ORDER NOW
Fluid (5 Options Available)
Corsair Hydro X Series XL5 Performance Premixed Clear Coolant - 1 Litre (CX-9060001-WW) @ £14.99 inc VAT
CX-9060001-WW, Clear Fluid, 1 Litre
Only £14.99 inc VAT.
ORDER NOW
Corsair Hydro X Series XL5 Performance Premixed Red Coolant - 1 Litre (CX-9060003-WW) @ £14.99 inc VAT
CX-9060003-WW, Red Fluid, 1 Litre
ORDER NOW
Corsair Hydro X Series XL5 Performance Premixed Blue Coolant - 1 Litre (CX-9060004-WW) @ £14.99 inc VAT
CX-9060004-WW, Blue Fluid, 1 Litre
ORDER NOW
All Corsair Water Cooling Products Available Here
All Corsair AIO Coolers Available Here
They do look cool ;) I might grab res, for ryzen3.
What about phanteks back watercooling panel? (Just to steal the thread) and is it compatible with evolv x?:D
In regards to the Phanteks product as soon as I get all the details I will post up a new thread to give out all the information. I should have more information after Computex but it is a sweet bit of kit.
