** CORSAIR NODE PRO COMPETITION - RGB EVERY SINGLE THING **
OcUK Staff
26 Nov 2014
Stoke
Introducing the Corsair Lighting Node Pro Kit, which combines an RGB control module and 4 individually addressable LED strips to create an RGB taste sensation. It allows control of the 4 included LED strips, along with up to 6 Corsair HD RGB Fans (sold seperately) all of which can be controlled using the Corsair Link software.
Stock will be available in the next 10-14 days so preorder now!
Corsair Lighting Node Pro, RGB Lighting Controller with Individually Addressable RGB LED Strips @ £49.99 inc VAT https://www.overclockers.co.uk/cors...lly-addressable-rgb-led-strips-cm-000-cs.html
The CORSAIR Lighting Node PRO provides individually addressable LED lighting with software control for unique lighting effects and vivid illumination of your PC.
Only £49.99 inc VAT.
ORDER NOW
If you simply cannot wait, and fancy a tasty freebie, I'm giving away the evaluation unit that I currently have sat on my desk to one lucky forum member. Entry is relatively simple, I want to see you RGB something. The crazier/funnier the better. Points will be awarded for ingenuity and effort. You have till lunchtime next Friday and we'll pick a winner at that point! Good luck.
Kurgen;30490929 said:
yeah and wheres the competition...
Whats the point of me writing these tasty forum posts if you're going to skim over them :)
Translation - It's **** and I don't want it, even for free ;) :D :p
ChugNorris;30490971 said:
Figured, so here's something just for the sake of it:
It's actually pretty cheap for what you get. Normally we use samples internally but as we already have 101 RGB solutions I thought it would be nice to let the forums have a chance at winning it :)
it is a 28CM RGB LED Aquarium Light
● Full waterproof LED bar design, provide oxygen for fish
● Come with a 24 key remote controller. The controller offers 16 colors / fading / dimming, which creates a beautiful effect in the aquarium
● You can also change the color with the switch if you can't find the remote controller
● High quality 5050 SMD chips, super bright
● Higher luminosity and long life span
● Low energy consumption and environmental friendly
● Safe and reliable
● Plug and play, easy operation
● You can use 2 or more led bars for a larger tank with one remote
● Color: RGB
● Waterproof: IP68
● Lumen: 200LM
● Remote controller powered by 1 X CR2025 battery ( included
