Corsair products quality control
22 Mar 2007
A while back I bought a Corsair 500R case that had a couple of broken parts & needed some help. Luckily Ace Modder passed on my details to Corsair who got in touch and (eventually) got me a replacement case for the trouble I'd had. (2 months to get a replacement :mad:)
After that my faith in Corsair products, and their after-service took a knock but I thought I'd still buy Corsair products. Ram upgrade has been fine but I bought a H100 Cooler from a competitor the other day as it was on special price and finally fitted it into my system today.
Fitting went ok, powered on & worked ok, but then we hit a snag.....
Two things. Firstly, the molex plug which is needed to power the pump on the H100, one of the pins is pulling out. So when connecting to a molex plug from the PSU, it's pushing the pin outwards, thus not giving a proper connection. The main problem with that is if the connection becomes loose, then the pump stops working. :eek:
(Touch wood it's been ok)
Secondly & more irritating, is the noise from the pump. It sounds like when a hard drive is thrashing when it's being accessed. So I checked all connections, to make sure it wasn't anything loose or catching (like the molex above). Also checked it wasn't either of the fans. Only when I disconnected the radiator fans and only had the pump running did it point to the actual pump itself making the noise.
Great! :rolleyes:
Connecting everything back up & trying the 3 different settings on the pump all of which made no difference to the noise. Just that irritating grating noise.
Google searching turned up a nice 19 page thread on the Corsair forums about the issue and it seems I'm not the only one. Most people with the problem have had to RMA the cooler and have tried all the recommended fixes, most with no success. Also, it's not limited to the H100, it can also affect the H80.
Now I'm not 100% on this but it seems the H50 (which I've `upgraded` from) & H60 are made by Asetek and the H80/H100 by Cool-It. So it seems it's limited to the Cool-it made models.
I'm going to run the system for a couple of days & hope the noise goes away, but I doubt it will. Although having the case laid on it's side stops the noise, but vertical as it should be = noise. Again it's a suggested fix, but doesn't stop it.
So with my past two Corsair purchases you can see that I'm not happy with Corsair products, or rather their quality control at the moment.
I can't knock their performance and generally I like their products & commitment to after-sales, but recent & current issues leaves me sceptical about Corsairs quality control.
RMA'ing a H100 cooler isn't going to be cheap & I don't like the idea that I'll be out of pocket for an obviously faulty product. I may just send it back to the supplier instead, as I'm not going to go down the same route as one poor guy who's on his 5th, yes 5th unit that have all had the same problem.
it does say on all the corsair stuff to RMA directly to them, and thats what i did as i assume it is a faster process :)
Maybe it is but the OP seemed more concerned about the cost:
I'm sure it'll cheaper to send it back to the retailer than to Corsair. Is their RMA to the Netherlands?
The retailer can't shirk their legal responsibilities and it might be easier to get the postage costs refunded by them than Corsair.
Edit:
Also if the OP has gone off the idea of the H100 he should be able to get a refund from the retailer if it's faulty.
Yeah I don't know what the cost will be to ship it back to Corsair in Holland, but it's a weighty box so it won't be cheap & it'll have to be tracked too.
But if I'm honest I don't want to have to ship it to Holland at all, but I suspect the retailer won't refund the cost of the postage, although it'll be cheaper to send to them than to Holland.
I'm just shocked that there's so many people with the problem. People have tried to narrow it down to batch numbers but it's not the case of a faulty batch, it just seems a design fault.
I know once bitten, twice shy & all that, but I doubt I'll buy Corsair products again & look elsewhere for my components and I sure won't recommend them to others.
Unless the retailer states in their Terms & Conditions that you are responsible for return postage then they will have to refund you.
I would feel the same if I were you. Take up you anger with Corsair and write them a grumpy letter (read: email) and see how they respond.
I'm not 100% sure if they do or don't tbh. Had a quick browse through their T&C and can't see it.
It's from the company that is part of an all in one printer ;)
I'm going to run it over the weekend, see if the issue persists, if it does then I'll return it as faulty to them next week.
Hope Neil Arnold sees this & can investigate why there's so many issues with these units.
Hi,
Interesting thread - I have a corsair case 600T and it is brilliant... sounds like you have been seriously unlucky overall :/
- what does RMA mean? I work for an online business and yet I have never head of this term.
- I am 99.9% sure that if your product is faulty and you return it to the retailer within the warranty period they have to pay your postage costs as per the distance selling regulations no matter what.
The business I work for always refunds postage costs when an item is faulty as this extra cost should not be placed on the customer.
I thought this was standard procedure.
Well I took it out of the case today & went back to my H50-1.
Admittedly temps are a little higher 35c at idle, sub-50 while gaming, it's not that much of a drop from the H100 cooling tbh.
Going to send it back to the retailer & get a refund instead of ****ing about with Warranty with Corsair. I didn't pay any postage with the retailer (due to a Forum membership deal) so I can't claim any back. I'll just incur the costs of sending it back to them, which is a pain.
Just to clarify, my suggestion was that you should ask them to refund the cost of the return postage so that you're not out of pocket.
Well it's going back to the e-tailor.
They're collecting it via the courier that delivered it. Initially it was set up as an RMA, but I told them it's for a refund.
Usual procedure is they'll test it then offer a refund if found faulty. Just hope they have the sense to not test it on a flat bed. It doesn't make a noise when laid horizontal, but when vertical, as in most cases it grinds.
Comparative temps are the H100 was about 5-10c cooler than my H50-1 at idle & load.
