Corsair RAM won't hit XMP/DOCP
Permabanned
1 Sep 2010
I recently completed a new build with the following specs:
  • Ryzen 9 3900X
  • Asus Strix X570-F Motherboard
  • Corsair Vengeance RGB Pro 32GB (4x8GB, CMW32GX4M4Z3200C16, listed as 'Ryzen compatible')
  • RTX 3080
My issue is that I can't seem to get the RAM to run at it's XMP/DOCP speed of 3200MHz. The PC will reboot but not POST, with the DRAM error LED illuminated. I then have to do a CMOS reset to get going again, which is becoming a chore.
The RAM defaults to 2666MHz speed otherwise.
I have attached a screenshot from Thaiphoon Burner and I suspect that it is misreading the kit's IC based on the XMP timings. It looks more like Samsung C-Die than B-Die.
BIOS is the latest stable release for this motherboard, SoC voltage is 1.1V, DRAM voltage is 1.36V.
Any suggestions on how I can get this kit working at it's rated XMP speeds? I did try to get timings from DRAM Calculator for Ryzen, but it doesn't support Samsung C Die.
Cheers!
i have the same problem I'm doing a 3700x build for a friend on b450 msi carbon max wifi motherboard with latest bios and it wont do the 3600 xmp i have had to drop to 3200 for it to work.
Seen this happenning a lot lately on reddit.
I couldnt figure it out until i cleared cmos via the battery and managed to boot. I had the Dram led on a d0 error. Latest bios aswell.
Im watching this space atm and see what others have figured out.
Tempted to do the F11e bios as im on F10 atm. (Gigabyte) Think its a waiting game until manufacturers roll out the other Bios version
Sorry I totally missed the responses to this thread - thanks all for your input!
My solution was that the memory was mislabelled as B-Die by Thaiphoon Burner, so I recalculated the timings as Samsung OEM die in Ryzen memory calculator and managed to get the 3200Mhz and timings working by manually inputting them into the BIOS. This die does mean that there is limited overclocking potential, but the advertised speeds and timings are achievable. DOCP still will not work at all. Bit naughty of Corsair branding this RAM as 'tuned for Ryzen,' but there we go.
