Corsair RBG Owners Club
25 Feb 2014
Holmfirth
**Corsair RBG Owners Club**
Welcome all to the k65/70/95 RGB club!
This thread is aimed at keeping all of those fancy profiles in one place!
Feel free to ask questions, discuss the software, and make sure to share your creations!
For now its probably best to sign up to the Corsair forums >>HERE<< which allows attachments. So make a thread on there, then duplicate the post here with a link to the file/thread and I will add it to the list! If you can, it is a good idea to make a short video and put it on Youtube so people can see your profile easily.
How to fix your \ and # keys not lighting up! (Incorrect Flash)
Step 1: Make sure you are running the latest version of CUE (Version 1.1.56) which can be found here.
Step 2: Update the keyboard firmware through the software.
Step 3: Manually clear the lighting for the \ and # key and re-assign the lighting.
User Profiles
K70 - Red Ripple - Kipz
K70 - Solid White, Rainbow Keypress - Deo volente
K70 - Two Red Profiles - Deo volente
K70 - Rainbow Seisure - Deo volente
K70 - Heat Sensitive - Kipz
Suppose ill go first to give an example of the format.
Just a simple red/white ripple profile. I made it so the ripple alternates colour for the alternate light colour clusters.
Link Here
K70 RGB
Just a simple white solid layout with a key specific rainbow and a breathing white mute button ( its a bit ghetto as it doesn't know if mute is on or not just activates on mute button press and deactivates on next press so make sure your mute is not on when you activate profile).
Vid added
Link here
How did you get the youtube to embed? Mine is just being a pain :(.
Edit: Figured out the youtube tags but its still not having it.
K70 RGB
2 red profiles that i use together.
First is red with with a black wave that travels top to bottom (i set this as default)
Second is solid red with a black per key ripple on key press (i set this to start on Firefox.exe)
then set auto profile switching on taskbar.
(sometimes they get mixed up a bit if you min/max firefox a lot)
Link here
Wow, looks like you need a degree in programming for CUE...
Think I'll steal Deo_volente's profile as my build is red/black theme. Looking really good tho guys, can't wait to see what you come up with given more time!!
K70 RGB
Made this hoping to get it to run when screensaver kicked in but it seems you can only set profiles to run on .exe where as screensaver extension is .scr (if anyone has any idea let us know please)
Link here
Looks really festive haha!
Ive got a pretty cool heat sensitive looking profile that Ill put up tomorrow when I get some time to upload the video.
Received mine today and have the firmware bug :( Ticket just created with Corsair, hope they are quick to respond.
